Old 03-13-2007, 05:37 AM
odieyodie odieyodie is offline
Question Glow to Electric Conversion
I am totally new to electric airplanes, having only built glow models to date. I have been reading about converting glow airplanes to electric and I need some advice. I have several airplanes (Ultra Sport 40, Topflite corsair, Topflite P-40E etc.) They range in glow engine size from .40 to .61. Is the conversion practical cost wise and power wise. Also what will I need to do this. Any info. is helpful.
Old 03-13-2007, 12:04 PM
Vince Vince is offline
I have converted a Telemaster SR with it's 8' wing. Dad's nitro version runs a .60 size glow. I run an AXI 4120. Similar performance.
I run a LiPo pack buiilt out of many smaller packs. The cells are 2100Mah and I run 6S3P. There are cheaper, bigger cells available today.
Vince
Old 03-13-2007, 02:44 PM
Whats it gonna cost?
Whats it gonna take to get these in the air cost wise?
Old 03-13-2007, 03:30 PM
$239 for motor and controller.
LiPo batteries... I paid $300 each for my flight packs that total up to be 22.2v and 6300mAh. This give about 12 minutes of full throttle. Prices have come down. There are packs of 3s 4200 batteries. 4 of those would give you a 22.2v 8400mAh pack, that would give you 16+ minutes of full throttle, and cost you somewhere in the $200 range.
Do you have a LiPo charger? Which one?
Old 04-05-2007, 01:37 AM
Any one out there know anything about the Turborix outrunner motors being sold on E-Bay. I bought 1000w 833/rpm ourtrunner to power my Great Planes Ultrasport 40 .40 gas powered airplane. Are there any tips on installing it and what batteries /prop should I be using.
Old 04-05-2007, 11:59 AM
aeajr aeajr is offline
Cool
I find this page a good starting point.
Combo 40 - Combo 90 are probably what you are looking for.
http://www.maxxprod.com/mpi/mpi-264.html
Look at the Watts column and figure about 75 to 100 watts per pound. The article explains the elements that go into that recommendation.
SIZING POWER SYSTEMS FOR ELECTRIC AIRPLANES
by Ed Anderson
aeajr on the forums
Revised 10/25/06
This may get a little technical but I will try to keep it as simple as I
can. I will draw parallels to cars and bicycles in many places as most
people can relate to these and know at least a little about how they work.
I will use round numbers where I can and will use some high level examples.
If you are an engineer you will see that I am taking some liberties here for
the sake of simplicity. I will go through the parts of the power system,
then, toward the end, I will show you how we tie these all together to come
up with a complete power system.
POWER = WATTS
I will be using the terms Volts, Amps and Watts throughout this discussion.
Let me define them.
Volts = the pressure at which the electric energy is being delivered - like
pounds per square inch or PSI in a fuel system or water from a garden hose.
Volts is about pressure, it says nothing about flow. You will see volts
abbreviated as V.
Amps = the quantity or flow of electricity being delivered, like gallons per
minute in a fuel system or that same garden hose. Amps is about flow, it
says nothing about pressure. You will see amps abbreviated as A.
Watts = V X A. This is a measure of the energy or power being delivered.
This is how we measure the ability of that electricity to do work, in our
case the work of turning a propeller to move our airplane through the air.
Watts is about both pressure and flow. This serves the same purpose as
the horsepower rating of your car's engine. In fact 746 watts = 1
horsepower. So if you had an electric car, the strength of its motor could
be reported in either watts or horsepower. You will see watts abbreviated as
W.
If you want more depth on this, visit this thread.
http://www.wattflyer.com/forums/showthread.php?t=1933
MOTOR EFFICIENCY - Brushed vs. Brushless
Whether brushed or brushless, the motor's job is to convert electricity into
mechanical motion to turn the propeller to move air. Efficiency is how we
measure how much of the power, the watts, that our battery delivers to the
motor is actually turned into useful work and how much is wasted as heat.
A higher efficiency motor delivers more energy to the prop, and wastes
less.
A typical brushed motor, say a speed 400, is only about 40-50% efficient.
Only about half the watts delivered to the motor actually end up as useful
work turning the propeller. The rest is wasted. Motors that have a "speed"
designation, like speed 400, are brushed motors. There are other names for
brushed motors but the "speed" term is a common one. They are inexpensive
and they work. For example, you can buy a speed 400 motor and electronic
speed control, ESC, for $30. A comparable brushless motor/ESC combination
would
typically cost 2 to 4 times that much.
Brushless motors tend to be more efficient. They typically deliver 70-90%
of that input power to the propeller, Thus you get better performance per
watt with brushless motors. Seen a different way, if you use a brushless
motor, then, for the same flying performance you will use less energy which
means your battery will last longer. Or you can use a similar size and
weight brushless motor.battery combo to get comparable performance
because the motor turns more of the watts from the battery into useful work
of turning the propeller.
As with many decisions we make, this is a cost benefit decision. Am I
willing to pay more to get more? That is up to you.
THE BATTERY IS MORE THAN JUST THE FUEL TANK
Think of the battery as the fuel tank plus the fuel pump and a supercharger
all rolled into one. It feeds/pushes energy to the motor. So you have to
look at the battery and the motor as one unit when you are sizing power
systems for electric planes. In many cases we start with the battery when
we size our systems because the motor can't deliver the power to the prop if
the battery can't deliver the power to the motor.
The higher the voltage rating of the battery, the higher the pressure, like
a supercharger on a car engine. More pressure delivers more air/fuel
mixture to the engine which allows the engine to produce more power to turn
the wheels of the car.
Higher voltage pushes more electricity into the motor to produce more power,
IF AND ONLY IF, the battery has the ability to deliver more electricity.
Again using the car analogy, if you put a big motor in a car and put a tiny
fuel line and a weak fuel pump, the motor will never develop full power. In
fact the motor might starve and stall once you got past idle. Such is the
same with batteries. We need voltage, we need capacity, but we also need to
know how many amps the battery is capable of delivering at peak.
If we compare an 8 cell AAA battery pack to an 8 cell C battery pack we get
9.6 V for both packs. However the AAA pack may only be able to deliver 6
amps. After that the cells will heat up and either be damaged or the
voltage will start to drop fast. The C pack, also 9.6 V, might be able to
deliver 60 amps without damage. So we have to size not only by voltage, but
by the ability to deliver amps to the motor. Again, think of the fuel line
and the fuel pump as your image of what I am trying to explain. If the
motor needs 12 ounces per minute to run but the fuel line can only deliver
8, the engine will starve and die.
Using our electric motors, a given motor may take 10 amps ( the quantity of
electricity flowing ) at 8.4 volts ( the pressure at which the electricity
is being delivered) to spin a certain propeller. We would say that the
battery is delivering, or that the motor is drawing 84 watts, i.e.: 8.4V x
10A. If you bump up the voltage to 9.6 volts, the battery can ram in more
amps into the motor, more energy to the motor, which will produce more power
to the propeller. In this example, if we move from an 8.4V battery pack to a
9.6V battery pack the motor may now take 12 amps. This will typically spin
the motor faster with any given propeller or allow it to turn a larger
propeller at the same speed.
However, if you bump up the pressure too much, you can break something.
Putting a big supercharger on an engine that is not designed for it will
break parts of the engine. Too much voltage can over power your electric
motor and damage it. So there is a balance that has to be struck.
Different motors can take different amounts of power, watts, volts X amps,
without damage. For example, a speed 400 motor might be fine taking 10 amps
at 9.6 volts or 96 watts. However bump it up to 12 volts and ram 15 amps
down its throat and you will likely burn it out.
Our goal is a balanced power system. If you match the right battery with
the right motor, you get good performance without damage to the motor. In
many cases airplane designers will design planes around a specific
motor/battery combination so that they match the size and weight of the
plane to the power system for good
performance.
PROPELLERS
Propellers are sized by diameter and pitch.
The diameter of the propeller determines the volume of air the propeller
will move, producing thrust, or pushing force. Roughly speaking the
diameter of the propeller will have the biggest impact on the size and
weight of the plane that we can fly. Larger, heavier planes will typically
fly better with larger diameter propellers.
Pitch refers to the angle of the propeller blade and refers to the distance
the propeller would move forward if there were no slippage in the air. So a
7 inch pitch propeller would move forward 7 inches per rotation, if there
were no slippage in the air. If we combine pitch with the rotational speed
of the propeller we can calculate the pitch "speed" of the propeller. So,
at 10000 revolutions per minute, that prop would move forward
70,000 inches per minute. If we do the math, that comes out to a little
over 66 miles per hour.
By changing the diameter and the pitch of the propeller we can have a
similar effect to changing the gears in your car or a bicycle. It will be
harder for your motor to turn a 9X7 propeller than an 8X7 propeller. And
it would be harder to turn a 9X7 propeller than a 9X6 propeller. The
larger or steeper pitched propellers will require more energy, more watts,
more horsepower, to turn them. Therefore we need to balance the diameter
and pitch with the power or wattage of the motor/battery system.
Fortunately we don't actually have to do this as motor manufacturers will
often publish suggested
propellers to use with a given motor/battery combination. We can use these
as our starting point. If we want we can try different propellers that are
near these specifications to see how they work with our airplane.
GEARBOXES
While unusual on glow or gas planes, gearboxes are common on electric
planes. Their primary function is similar to the transmission on a car. The
greater the gear ratio, the higher the numerical value, the slower the
propeller will turn but the larger the propeller we can turn. So you can
use a gearbox to help provide more thrust so you can fly larger planes with
a given motor. However you will be turning the propeller slower so the
plane will not go as fast.
With direct drive, that is when the propeller is directly attached to the
motor shaft, we are running in high gear ( no gear reduction). Like pulling
your car away from the light in high gear. Assuming the motor doesn't stall,
acceleration will be slow, but over time you will hit a high top end!
Typically direct drive propellers on a given motor will have a smaller
diameter.
With the geared motor, it would be like pulling away from the green light in
first gear - tons of low end power and lots of acceleration, but your top
speed is reduced.
So, by matching up the right gear ratios made up of the propeller and,
optionally, a gearbox we can adjust the kind of performance we can get out
of a given battery/motor combination. How this is done is beyond the scope
of this article.
NOW WE CAN START TO MATCH UP THE PIECES!
The simplest approach I have seen to figuring power systems in electrics is
input watts per pound of "all up" airplane weight. The following guidelines
were developed before brushless motors were common but it seems to hold
pretty well so we will use it regardless of what kind of motor is being
used.
50 watts per pound = Casual/scale flying
75 watts per pound = Sport flying and sport aerobatics
100 watts per pound = aggressive aerobatics and perhaps mild 3D
150 watts per pound = all out performance.
Remember that Watts = Volts X Amps. This is a power measurement.
In case you were wondering, 746 watts equals 1 horsepower.
AN EXAMPLE!
This should be fun. Let's see where these formulas take us! We will use a
24 ounce, 1.5 pound plane as our example. If we want basic flight you will
need 50 watts per pound or about 75 watts input to your motor for this 1.5
pound plane. That is, 50 watts per pound X 1.5 pounds = 75 watts needed
for basic flying performance. If you want a little more spirited plane, we
could use 75 watts X 1.5 pounds which is about 112.5 watts.
Lets use 100 watts as the total target, just to be simple, shall we? I am
going to use a lot of round numbers here. I hope you can follow.
The Battery:
If we use an 8 cell NiMh battery pack at 9.6 V it will have to deliver 10.4
amps to hit our 100 watts input target ( 100/9.6 = 10.41amps) If my
battery pack cells are NiMh cells that are rated at 10C then I need an 8
cell pack rated at 1100 mah to be able to deliver 11 amps. Sounds about
right.
Now I select a motor that can handle 100 watts or about 10.4 amps at 9.6
Volts. From experience we know this could be a speed 400, a speed 480 or
some kind of a brushless motor.
We now need a propeller that will cause the motor to draw about 100 watts. I
don't know off the top of my head what that would be. I would go to some mfg
chart as a starting point. GWS has good charts!
http://www.gwsus.com/english/product...tem/edp400.htm
I see that if I use a direct drive speed 400 with a 5X4.3 prop at 9.6V then
the motor will draw about 12.4 amps or about 119 watts. This would be a
good candidate motor/prop for the plane using a 9.6V pack that can put out
12.4 or more amps. This would be a set-up for a fast plane as that motor
will spin that small prop very fast.
However maybe I don't want such a fast plane but one with a really good
climb and lots of low end pull to help out a new pilot who is in training or
to do more low speed aerobatics
I can also use a speed 400 with a 2.38 gearbox and run it at 9.6V spinning a
9X7 prop and run at about 12.8 amps for 120 watts.
http://www.gwsus.com/english/product...em/eps400c.htm
The larger prop will give this plane a strong climb, but since the prop
speed has been reduced by 2.38 times, it won't be as fast. Spinning a
bigger prop gives me more thrust but a lower top speed typically. This is a
common strategy for 3D planes.
Back to battery packs and motors
So if I shop for a 9.6V pack to be able to handle about 15-20 amps, I should
do just fine and not over stress the batteries. In NiMh that would probably
be a 2/3 or 4/5 A pack of about 1000 -1300 mah capacity.
We view the battery and motor as a linked unit with a target power profile,
in this case about 100 watts. We use the prop and gearbox, if any, to
produce the manner in which we want to deliver that power to the air to
pull/push the plane.
If this is a pusher, I may not have clearance to spin that big prop so I
may have to go for the smaller but faster prop combo.
If this is a puller, then I can choose my prop by ground clearance or some
other criteria and match a gear box to it.
See, that was easy, right? ( well sorta but ....)
But we are not done! Oh no!
I could try to do it with a 2 cell lithium pack rated 7.4V. To get 100 watts
I now need a pack that can deliver 13.5 amps and a motor/prop combination
that will draw that much. So if I have 10 C rated lithiums, then the pack
better be at least 1350 mah. Probably use a 1500 mah pack to be safe.
Well, when I look at the chart for the geared speed 400 I see that,
regardless of prop, at 7.4V I am not going to have enough voltage (
pressure) to push 13 amps into this motor. So the 2 cell lithium won't meet
my performance goal of 100 watts+ per pound using this gear box.
If I go back to the charts and look at a different gear boxes I can't hit my
power goals using 7.4V. Maybe we go back to direct drive.
We see that the best I can get this speed 400 to do is a total of 70 watts
at 7.2V ( close enough ) so I can't hit my power goals using a speed 400 at
this voltage. but 70 watts would be about 48 watts per pound so I could have
a flyable plane, but not an aerobatic plane using this two cell pack.
REALITY CHECK!
Now, in fact that is NOT how I would do this. I would decide on the watt
target, go to the chart, find a combo that meets my goals, then select a
battery that will meet the demand and see if my weight comes up at the
target I set. A little tuning and I come up with a workable combo.
For those who like to be even more analytical about it, there are packages
like MotoCalc that will allow me to play with all sorts of combinations and
make suggestions on what I should use. There is a link for MotoCalc below.
Summary
So, in these few paragraphs you have taken in a basic knowledge of how
electric
power systems are sized, the factors that are considered an how to predict
the outcome. Simple, right?
Of course there is a lot more to know and time and experience will teach
you plenty, but with this basic understanding you are better prepared to
begin playing with the power systems you put in your planes.
Here are some additional resources that may be helpful.
Good luck e-pilot!
Clear Skies and Safe Flying!
Ed Anderson
Brushed Motors
http://www.hobby-lobby.com/elecmot.htm
Brushless Motors
http://www.hobby-lobby.com/brushless-motors.htm
Brushless outrunners explained
http://www.diynetwork.com/diy/rc_pla...834_02,00.html
Battery Packs - NIMH
http://www.cheapbatterypacks.com/mai...=445976&ctype=
http://www.hobby-lobby.com/hydride.htm
Battery Packs - LiPo
http://www.cheapbatterypacks.com/mai...gid=tp&sort=PL
http://www.hobby-lobby.com/lithium-polymer.htm
Lithium Balancers and Balancing Chargers
http://www.rcgroups.com/forums/showthread.php?t=599287
Gearboxes - Speed 400 & 480 examples
http://www.hobby-lobby.com/gear400.htm
http://www.hobby-lobby.com/gear480.htm
A series of posts on electric power system basics
http://www.rcgroups.com/forums/showthread.php?t=417868
Maxx Products has a pretty good tip sheet on coming up
with a glow to electric power comparison. You can find it here:
http://www.maxxprod.com/mpi/tips3.html
This reader says Keith Shaw originated the watts per pound rule
http://www.rcgroups.com/forums/showp...0&postcount=39
MotoCalc
MotoCalc will tell you everything you need to know: Amps, Volts, Watts, RPM,
Thrust, Rate of Climb, and much more! It is a popular tool for predicting
the proper motor, prop, battery pack for electric planes.
http://www.motocalc.com/
This club has some interesting links on their home page that may be helpful
in planning props and power systems.
http://www.srcmc.co.uk/
Drive Calculator Version 2.21
Based around a Microsoft Excel spreadsheet This includes a propeller thrust
and power database, in a similar form to MotorXL, a motor database, and
tools for predicting home made motor performance. With these tools it is
possible to predict the performance of motor and prop combinations - even
with custom motors!
http://www.badcock.net/motorcalc/
The Great Electric Motor Test
http://www.flyingmodels.org/motortest/index_e.htm
Old 04-05-2007, 12:27 PM
tailgunner tailgunner is offline
Talking
I dont have any turborix by the look like daulsky motors I have 3 of them they work fine.
E-flite has the best conversion system: power 10 = glow size 10
power 25 = 25size glow and so on up to 160 as of now
I have a power 25,32,46, and 2 power 60s they all outperform ther glow equvelant.
Im not saying they are the best motor just the easiest conversion system.
I also have an AXi, rimfire and some of the cheep chiniese cr#$%.
If the price seems to good it usualy is but I too had to try.
How heavy is your plane ?
150 watts per lb will give incredible perforformance
200+ watts per lb will give unlimited 3-d virticals
hope this helps
Old 10-17-2007, 05:30 PM
Ryan CSRC Ryan CSRC is offline
The most expensive single item is probably the battery so you should make sure and choose the right one, especially if you want multiple packs for longer flight times. One thing to keep in mind is that if you want longer run times, you probably do not need very high C packs, so you can get cheaper yet still high quality packs for fairly cheap if you get only the C rating you need. For example check out the 8c packs on our website in the battery section. Something like this could be a good way to keep costs down.
Ryan Lefevre
www.CommonSenseRC.com
The Go To Guys for Electric Power
