Radio Control Zone » RC Car Action: Forums » General Vehicle Forums » General RC Discussion » What does a 25:1 ratio of fuel mixture mean?
Old 04-23-2006, 08:32 PM
EZM's Avatar
EZM EZM is offline
I have a super pocket bike and says i should mix 2 stroke oil and fuel to run in the bike, but i dont know how much that is? If it helps ,the tank capacity is 0.5 gallons, If you guys could just tell me how to measure it and how much that ratio is i would be okay.
Old 04-23-2006, 10:02 PM
Duffil Duffil is offline
25:1 means 25 parts fuel and 1 part oil. It's normally easiest to mix in larger quantities than 1/2 gal.
this might help: http://www.rctek.com/pdf/fuel_to_oil_ratio_chart.pdf
NOTE: THIS IS A PDF, YOU NEED ACROBAT READER TO VIEW IT.
basically, for 25:1, you need 5.12 oz of oil per gallon.
Old 04-24-2006, 01:09 PM
mook mook is offline
Hi ezm
Trek down to your local B&Q or Homebase (DIY store) and pick up a 2 stroke mix bottle. They cost about £7. You put a litre of fuel in the bottle, then add oil to where the 25/1 ratio is marked----> on the side of the bottle.
It takes the guess work out and is accurate
Btw,you might need a funnel to get the fuel in.
Also, the mix bottles are meant for petrol only
http://www.screwfix.com/app/sfd/cat/...p=tx3&id=43987
edit: If interested, then best check that the mix bottle has the 25/1 ratio marked on the bottle, before (if) you buy
Old 04-24-2006, 09:07 PM
E-MO E-MO is offline
Or in the states they call it a ratio rite
you can get them at auto parts/motocycle shops
find the line that says25:1 fill with 2 stroke oil
dump oil in one gallon fuel jug
go to gas station fill with one gallon of fuel
filler up twist a grip!
wear a helmut
Old 04-25-2006, 06:24 PM
ososlow's Avatar
ososlow ososlow is offline
I usually do it with 20L jerrycans. Fill up the can and pour in just under a liter of oil. I usually end up mixing it a little rich though.
Those containers look pretty handy. I always need more than a couple liters though unless it's for a chainsaw.
Old 07-08-2011, 06:49 AM
michael09121 michael09121 is offline
Smile
Originally Posted by mook View Post
Hi ezm
hi,
that has really helped me because i have a mini poket bike and i cant find out what 25:1 ment, could it be any sort of petrol? because i have unleaded and diesel would any of them work in it with the 2 stroke mix?
michael
Old 07-08-2011, 09:16 AM
Lille Buller Lille Buller is offline
unleaded petrol is fine, diesel will pretty much kill your bike..
Old 07-08-2011, 08:26 PM
trugsta's Avatar
trugsta trugsta is offline
A high octain Unleaded fule will work best with the 25/1 mix.
It may cost alittle more per gallon/litre but its worth it...
