Latest from Serpent:
The kit includes car, clear body with mask, 4 racing wheels, rear wing, decal and full color manual. The full package to compete in high end racing, finish finals and win ! Shipping middle of march 2013.
This new development for Cobra buggy is realized after another full year of racing across the globe, listening to feedback from many (team)-drivers and dedicated testing on many different surfaces. The feedback from the drivers on the Cobra Buggy in general is very good, the durability is rated as best in the market, the shocks are top-rated, and the diffs and drivetrain with new gears and larger bearings can now withstand any rigors and will last and last ! According to same drivers a more responsive rear end, combined with a bit more steering would bring the Cobra on the highest level.
Well, the changes as below accomplish just that, and for sure we will continue the superb quality on the kit overall!
Key changes for the 2.0 version:
- Improved rear geometry with wider rear lower arms, new uprights and new shock position
- Longer rear shocks and higher rear carbon shock tower for more travel
- Shocks moved to the back, to make access and adjusting easier, and make rear end more stable and responsive
- rear wing with integrated holders for the balanced rear anti-roll bar
- lexan mud-guards to mount on lower rear arms
- nylon mud-scrapers mount on the rear uprights
- improved differential gears - as already in the Be version
- larger bearings in steering blocks and uprights 8X16X5 (2) and 15x21x4 (2),
- transmission using larger bearings 8x19x6 and 13x19x4 and new couplers for extra durability
Chassis plate
Chassis plate in 3mm 7075 T6 aluminum , with machined pockets to create flex make lighter. Kick-up angle on front for stabile landings. Countersunk holes. Slots to locate the front and rear suspension mounts precisely. Angled sides to increase stiffness. Laser engraved Cobra logo.
Bumper
Aligned with chassis kick-up for precise landings and to protect front suspension holder and anti-roll bar.
Chassis stiffeners
Composite stiffener front and rear, to give extra stiffness, but still allow some flex as needed.
Central radio / servo mount
Composite compact radio box which offers good space for the steering servo and the receiver . The whole assembly including linkages can be taken off easily and fast in one go, when cleaning the car, or doing maintenance.
Battery-cases / side-guards
The main eye catchers are the extremely low laydown longitudinal placed battery-packs at each side of the car, being part of the side-guards, securely fastened with a flip-lid, for easy and fast battery changes. The weight low in the car and in the right position, well balanced. The Lipo holders comply with ROAR legal packs / dimensions.
Motor mount:
The motor is placed in the most optimal position in the car, keeping motor-forces and transmission parts / alignment in mind. Only one-screw is needed to secure the BL motor, in the nicely designed durable machined aluminum motor mount. Space for additional motor-cooling available as needed.
The space for the motor allows a maximum motor-length of 70mm, which covers most widely used motors ( except for the truggy / monster truck motors).
Suspension brackets
Beautifully machined 7075 T6 suspension brackets in anodized, laser engraved. Precision fit for the nylon roll center inserts and pivot balls / pins.
Steering blocks assembly
Composite steering blocks combined with 10 dgr C-hubs for precise steering. Spring steel wheel-axles with large size bearings and larger inner with precision threaded aluminum wheel-hubs with offset . Flanged and serrated wheel nuts to guarantee that you will not lose a wheel nut in a race.
Front suspension
Durable oversized lower suspension arms in strong composite nylon. On the lower side the special shaped down stops screws are mounted. The lower shock-mounting pins are secured with a small grub screw from the bottom.
Front anti-roll bar
The balanced front anti-roll bar system, consist of a spring steel bend wire, which is guided through the diff-cases and runs in balanced steel adaptors. The wire is linked to the lower suspension arm, with a captured adjustable threaded pivot ball, for very precise and low friction operation and easy tuning.
Shock tower and body mounts front
4.5mm thick carbon shock tower with 5 upper positioning holes for the shocks and 6 holes for roll-center positions. 1 centrally located adjustable body mount , and 2 forward mounted adjustable body mounts, all with flip-tops.
Angled steering system / servo saver
The bell cranks are angled to reduce the angle of difference between the total caster and steering plane. Therefore you will have less bump steer and a truer steering Ackerman through the entire range of suspension
Ackermann plates
With the design of the steering bell cranks when changing the Ackermann you will not need to adjust your steering tie rods. You simply will only need to adjust your end points on your radio..
Rear suspension arms
Durable longer oversized lower suspension arms in strong composite nylon. On the lower side the special down stops screws are mounted. The lower shock-mounting pins are secured with a small grub screw from the bottom.
Mud-guards
Superlight polycarbonate mud guards mount to the new lower suspension arms, and will keep dirt away from your anti-roll bars transmission and wheels.
Rear uprights assembly
Composite uprights with 3 upper roll-center positions. Strong steel track-rods with L/R threading and strong ball joints to pre-set camber. Spring steel wheel-axles with large size bearings and larger inner ones with precision threaded aluminum wheel-hubs with offset . Rubber dustcovers in the rear to protect the cvd system and keep the lubrication inside. Flanged and serrated wheel nuts to guarantee that you will not lose a wheel nut in a race.
Mud scrapers
Composite mud scrapers which mount to the new uprights, and will keep the inside of your wheel cleaner in case of muddy conditions. Kept on the bigger size, so may need to grind to fit your brand of wheels.
Rear anti-roll bar
The balanced front anti-roll bar system, consist of a spring steel bend wire, which is guided through the rear wing mount and runs in balanced steel adaptors. The wire is linked to the lower suspension arm, with a captured adjustable threaded pivot ball, for very precise and low friction operation.
Shock tower rear
4.5mm thick carbon shock tower, integrated into the rear section for extra stiffness, with 5 upper positioning holes for the shocks and 6 holes for roll-center positions.
Wing mount and body mounts rear
Composite rear wing, with strong nylon adjustable rear body mounts on wide body-support bridge located far enough to the rear, to support the bodies in best way.
Captured pivot pins and balls and bolted hinge pins
All spring-steel hinge pins are either captured or bolted in place and made in spring-steel quality. This insures your chances to finish an hour long main event, while battling for the lead. This relieves stress on the hinge pin when adjusting the kick up, or anti squat. Your pin is free to rotate to any angle without binding.
Shock absorbers RCM big-bore 16mm
Hard Teflon coated threaded shock bodies with 4mm shock-rods. Hard anodized aluminum screw on shock-tops with Serpent laser engraving. Pre-load adjusters with O-rings inside. Shocks use large diameter membranes and large diameter O-rings and bushings to create a super smooth and leak-proof package. Large diameter pistons are held in place by a nut on the polished shock-rods tops. Open type spring retainer to let dirt out easy. The shock-shafts are protected by rubber boots.
RCM shock springs
Color-coded progressive shock springs are supplied for the 1st standard set-up and all springs are grinded flat top and bottom, and checked individually for tension and length and matched.
Compact gear differentials
Very compact gear differentials with very smooth metal sintered gears, and steel shaft. Perfect sealing case with special gasket and O-rings. Very light and durable outdrive cups in spring-steel. Hardened spring-steel diff-coupler 13T with connector running in 2 oversized bearings The Cobra-E uses a 13T / 44T combo gearing. 46T central diff gear. This drive ratio will provide amazing acceleration combined with the low vehicle weight.
Front and rear cvd-sets
Both front and rear captured driveshafts are being used with CVD system. Durable yet light spring steel engraved driveshafts with hard steel pins.
Spring steel transmission parts
The front and rear thin but strong spring steel carbon shafts connect the differentials .
Body
Serpent super low Cobra E buggy body with film and masking tape is included in the kit.
Rear wing:
Low version strong rear white aero rear wing is included for great down force and straight line stability.
Oils and grease
The shock-oil, diff oil and some grease is supplied to meet the standard set-up.
Manual and set-up
Full color manual with easy to follow assembly steps, exploded views for easy spares ordering, a blank and standard set-up sheet for a good start set-up.
Decals
Black and white promo body-decals ; Serpent generic and Cobra ones.
Packing
Parts are packed according to the steps explained in the manual.
Service and Support
The Serpent distributor, dealer or agent is your source for more info, but also the Serpent website and the member section and the YouTube channel provides lots of information.
#600012
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
