| Hot News and New Stuff Forum Cars, Trucks, Boats Where other RC websites and RC media get their news |
02-06-2013, 01:16 PM
Racers Edge SOLO80 Prime Multi-Chemistry Balance Charger
Latest from Racers Edge:
Racers Edge Prime Chargers are capable of handling all of your charging needs while offering features you can't find anywhere else. A full aluminum case with heat sink and built in cooling fans keep temperatures in check while the amps are flowing. An intuitive blue backlit display keeps navigation simple while handling the complexities of every battery chemistry on the market. Take your charging to the next level utilizing each chargers battery deck; with custom die cut logo foam pad, allowing your pit space to be maximized while wrenching. Built in balance software, a complete lineup of adapters, along with our unique Pro Bullet Harness, takes care of everything in your stable. There’s even a blank lead for your own customization. On top of all that there is a USB charge port for keeping your phone peaked during race days. Storage and transporting your charger has never been easier with our custom aluminum carrying cases, printed with our specs and models so your competition will be sure to know how much power is in your pit.
Specs:
- AC Input: 100-240v (100w-90w)
- DC Input: 11-18v
- Circuit Power: Max.
- Charge Power 80watts
- Max. Discharge Power 10watts
- Charge Current Range: 0.1 - 6.0amps
- Discharge Current Range: 0.1 – 2.0amps
- Current Drain For Balancing: LiPo: 300mA/cell
- NiCd/NiMH Battery Cell Count: 1 – 15cells
- LiPo/LiFe/LiIon Cell Count: 1 – 6cells
- Pb Battery Voltage: 2-20volts
- USB Port: 5volts - 1amp
- Display: Blue Backlit LCD
- Net Weight: 893grams (1.97lbs)
- Dimensions: [width|height|depth] 137mm x 88mm x 137mm
- Warranty: 5 year Manufacture Defect
Includes:
Pro-Connect Bullets, Alligator Clips, Tamiya connector, Deans® Ultra Plug®, Traxxas HC, Futaba RX, JST and open charger leads. Also included are a XH 2-6S balance board, removable DC input leads and an aluminum carrying case.
RCESC1800 - $149.99 MSRP
02-06-2013, 02:11 PM
takes care of all of your charging needs with 80 watts and 6 amps...What is this, some kind of sick joke?
Thats not even enough power to charge a 4s cell at 6 amps...
Original Join date 2001, username "fastharry" 1300+ Posts, Racing since 1996, HPI Challenge winner. A Main Finalist HPI Worlds
02-06-2013, 05:08 PM
Hah, you beat me to it. I do like the battery holder on top, but does that heat up the battery while charging giving a false read on voltage? Don't LiPos actually increase voltage with temperature, and a hot battery would have its charge terminated earlier than a cool battery. Just a thought.
Does look neat though, and I like the USB outputs on all the new stuff coming out.
