Latest from Tamiya:
The Farm King is an R/C assembly kit based on the popular WR-02 2WD platform. The WR-02 platform was first introduced on the Wild Willy 2, which comes with a pre-assembled gearbox and thanks to clever weight distribution is easy to wheelie by “blipping” the throttle on the transmitter. The newly designed tractor body shell is a reproduction of a farm vehicle often seen in farms across the U.S.A.
Scale 1/10 scale
Construction type: assembly kit
Terrain use: multi-purpose
Drive-train: 2WD RWD
Drive type: gearbox
Drive line: dog bone
Differential type: gear
Suspension: fully independent double wishbone
Steering mechanism: direct servo
Shock damper: friction damper
Shock damper material: plastic
Tire type: rubber
Tire tread: chevron
Body material: polycarbonate
ESC: included
ESC type: TEU-105BK
LED Light buckets: no
LED lights: no
Motor type: 540-brushed type
Bearings: plastic bushing
Chassis material: plastic
Sticker material: vinyl
Internal gear ratio:
Adjustable camber: fixed
Adjustable toe angles: front only
Adjustable ride height: yes
Adjustable gear ratio: fixed
Adjustable wheelbase: fixed
Adjustable track width: fixed
Adjustable shock angle: fixed
Special features: Includes wheelie bar and driver figure, pre-assembled gearbox
Requires: 7.2 battery & charger
Requires: polycarbonate paint
Requires: radio gear, servo, receiver
58556 - MSRP: $250.00
Availability: February
