Latest from Venom:
Venom is proud to bring you The Venom Stronghold Solo, the ultimate in safe battery charging. This heavy-duty stamped aluminum box minimizes potential damage and features a shatterproof polycarbonate window for visual monitoring of your battery packs during charging or discharging. The Stronghold Solo comes with a long lead balance block, allowing seamless operation with a charger of your choice (Not Included). The Stronghold Solo was designed to help contain fire and gasses by dissipating the pressures at a controlled rate and is rated for lithium batteries up to 60-watt hours. Never before has it been safer to charge your battery. Get some piece of mind… get a Stronghold Solo.
*NOTE: The use of the Venom Stronghold Solo does not eliminate the risk of a lithium polymer battery fire. Users should always follow the safety warnings, instructions and guidelines provided by their battery and charger manufacturers in connection with this product.
- Heavy-duty stamped aluminum case
- Aluminum carry handle
- Designed to contain LiPO packs up to 60-watt hours
- Balance block with extra long leads
- Hinged lid with polycarbonate window for easy battery observation
- Rubber feet protect the surface it rests upon
- Positive snap latch makes it a great carrying case for batteries
- Reusable - does not require replacement like a LiPO charge sack.
Dimensions: 9.25x6x4.25in (235x154x108 mm)
Weight: 1.9 lbs
Max Battery Size: 60 Wh
Balance Block: 2-6S JST XH. Extra long leads.
(Compatible w/ Pro Charger, Stronghold 25A, and
Medion Dual 10A charger.)
The Venom Stronghold Solo is rated for Lithium Polymer batteries up to 60-Watt Hours:
Cells Voltage Maximum Capacity Watt Hours
2S 7.4V 8000mAh 59.20
3S 11.1V 5400mAh 59.94
4S 14.8V 4000mAh 59.20
5S 18.5V 3200mAh 59.20
6S 22.2V 2700mAh 59.94
0672 - Venom Stronghold Solo Charge Box - $69.99 MSRP
