Latest from Spektrum:
If youre looking for a surface transmitter that can do it all, the DX4S is it. Not only does it give you the flexibility of four channels, but it includes an impressive array of programming features. This includes pre-set mixes like 4-wheel steering, two user-defined mixes, on-the-fly mix rate control, ABS and more.
At the core of the DX4S is the frequency-agile, DSMR™ 2.4GHz protocol. DSMR is exclusive Spektrum™ technology that can be used with any type of RC surface vehicle, including boats. Its range and response, particularly in noisy 2.4GHz environments, is superb. Its also backwards compatible with DSM, DSM2 and Marine-specific Spektrum receivers. Longtime Spektrum users wont need to replace the receivers they have unless they want the frequency-agility of a DSMR receiver for busy 2.4GHz environments.
* The typical telemetry range is 100-200 feet and will vary depending on the operating environment.
- Backlit LCD
- 30 Model memory
- 3 Grip sizes
- Integrated Telemetry (requires a DSM® telemetry compatible receiver)
- 2 User-defined, programmable mixes
- Pre-set mixes, including 4-wheel steering
- Switch-activated mix rates
- ABS
- Vibe alerts
- SD card reader
- On-the-fly mix rate control
- Integrated antenna
- Inactivity alarm
# of Channels: 4
Modulation: DSMR
Band: 2.4GHz
Weight: 17 oz (482 g)
Frame Rate: 11 or 22ms (with DSMR receiver
Receiver: SR410
Model Memory: 30
Modes: Expert and Standard
SPM4000 - $279.99
Due Early December, 2012
