Latest from KO PROPO:
Custom Aluminum Light Weight Screw Kit
- In-house custom modification for the EX-1 KIY Master
- Unit and 3D Extension Unit for EX-1 KIY.
- Aluminum screws anodized black in the USA for quality.
- Replaces 41 steel screws for aluminum screws in the
- Master Unit reducing the weight by 7.43g.
- Replaces 27 steel screws for aluminum screws in the
- 3D Ext Unit reducing the weight by 9.36g.
- Permanent modification that cannot be reversed.
- Available from KO PROPO America only.
Ulti Racing Tires
Debuted last week at the IIC race in Las Vegas, KO PROPO America is the exclusive North American importer of Ulti Racing Tire products. Product range from 1/12th, 1/10th and 1/8th scale foam tires and made in Japan.
- Every tire is sorted for it’s harness using a durometer and measured in three points for accuracy.
- Materials are in top quality and optimal conditions from manufacturing until you open the resealable bag.
- The carbon rim provides ultra lightness, massive strength and extreme precise accuracy.
- 1/12th foam available is J- standard foam, X- foam for tire treatment and Z-foam for high grip.
