Old 11-22-2012, 12:40 AM
Chilly Duncan Chilly Duncan is online now
Pro-Line November 2012 Releases
Latest from Pro-Line:
True Scale Ford F-150 Raptor SVT Clear Body for Short Course Trucks
This is a True Scale Ford® F-150 Raptor SVT Clear Body for the Slash® 2WD, Slash® 4×4 and SC10 (requires Pro-Line Extended Body Mounts). It is time to man up and go REAL with Pro-Line’s new True Scale Ford® F-150 Raptor SVT truck body for Short Course Trucks! Pro-Line now gives you the option to convert your Slash® and SC10 Short Course Truck into a True Scale Lifted Truck. This scale truck body is perfect for making your friends jealous and giving your Truck a completely different look! Don’t show up to the local bash spot or track with the same body as everyone else… Get your True-Scale Ford® F-150 Raptor SVT body from Pro-Line today!
#3389-00
Big Blox Off-Road 1:8 Buggy Tires for 1:8 Buggy Front or Rear
This is a pair of Big Blox Off-Road 1:8 Buggy Race Tires. Introducing the Ultimate Long Wear tire – Pro-Line’s all new Big Blox. Customers and Racers continue to demand higher and higher performance out of 1:8 Buggy Race tires while also requiring tires that last longer and longer. After much consultation and input from top-level Pro-Line drivers both in the U.S., Europe and across the Globe, Pro-Line has developed the all-new Big Blox Race Tire to meet these lofty expectations. Large center lugs formed into a grid pattern provide the base for the long wear characteristics and unmatched mechanical grip found by all test drivers.
The Big Blox tire also pays homage to Pro-Line’s rich racing heritage and 30th Anniversary with Bow-Tie shaped lugs that scoop the Earth and propel your Buggy to the top step of the podium. Great care was taken in detailing the side tread to achieve the same smooth side bite and steering feel found in Pro-Line’s highly successful Multi-time National Champ Blockade Race Tire. The Large Lugs on the Big Blox allow racers to choose softer compounds than previously possible while still lasting through long A-Mains. Step into the Big Time with Pro-Line’s new Big Blox!
#9048-01 M2 (Medium)
#9048-02 M3 (Soft)
#9048-03 M4 (Super-Soft)
Masher 2.8″ (Traxxas® Style Bead) All Terrain Truck Tires for 1:10 Truck for Front or Rear
This is a pair of Masher 2.8” Truck Tires. Pro-Line is bringing back one of the most popular Monster Truck Tires of all-Time: The Masher! The ultra-modern Chevron Style tread digs deep into the roughest and toughest terrain and looks mean doing it. The side tread of this behemoth tire features a hook shape that craters the dirt and achieves unparalleled side traction. The Masher 2.8” tire features the new Traxxas® Style Bead design giving you tons of wheel options. The tire will fit on any of Pro-Line’s 2.8” Traxxas® Style Bead wheels, as well as any stock 2.8” Traxxas® wheel! After fitting your truck with this massive Masher tread you’ll be ready for back yard thrashing and mashing on any neighborhood terrain. The Masher 2.8” tire is perfect for the Traxxas® Stampede® and Traxxas® Monster Jam Replica Trucks! Impress your friends – Get a set of Mashers today!
#1192-00
Ridge-Line Bumper Set
This is a Pro-Line Ridge-Line Bumper Set. As True Scale Crawling continues to evolve, Pro-Line recognizes the need for ever more realistic accessories. With a passion for detail, and a desire to meet / exceed these needs, Pro-Line is pleased to announce our latest in scale crawler accessories, the Ridge-Line Bumpers.
Wide Set (6088-00) fits SCX10, REVO®, Summit® & T/E MAXX®. The Narrow Set (6088-00) fits Axial Wraith (Front Only), SCX10 w/Narrow Bodies, REVO®, Summit® & T/E MAXX® w/Narrow Width Bodies.
This is a Pro-Line Ridge-Line Bumper (Narrow) Set for Axial Wraith (Front Only), SCX10 w/Narrow Bodies, REVO®, Summit® & T/E MAXX® w/Narrow Width Bodies.
Ridge–Line Heavy Duty Bumpers are manufactured with the Scale Crawler enthusiast in mind. The 6088-00 bumper kit comes with 5mm LED Light mounting points as well as dual tow points. The 6089-00 bumper kit comes with 3mm and 5mm LED Light mounting points as well as dual tow points. There’s also realistically simulated roller fairlead along with several mounting points for can lights or other scale accessories. Access ports through the bumper and brackets allow for behind bumper mounting of real scale working winches (Not Included).
The 6088-00 Narrow kit will fit narrow crawler bodies up to 5.750” wide or you can trim the ends to accommodate bodies over 6” wide. If you want to go W I D E then see #6089-00 Wide Kit.
The 6089-00 Wide kit will fit Truck / crawler bodies up to 7.5” wide or you can trim the ends to accommodate bodies over 8” wide. If you want to go Narrow then check out the #6088-00 Narrow Kit.
#6099-00 Wide Set for SCX10, REVO®, Summit® & T/E MAXX®.
#6098-00 Narrow Set for Axial Wraith (Front Only), SCX10 w/Narrow Bodies, REVO®, Summit® & T/E MAXX® w/Narrow Width Bodies.
PRO-2 Bumpers for 2WD Slash®
#6095-00 is a PRO-2 Front Bumper and Bulkhead for the Slash® 2WD. Pro-Line is proud to introduce an all-new Race-inspired Front Bumper, Brace and Bulkhead for the 2WD Slash®. The Slash® is the most successful Short Course Truck ever made and now you can add Pro-Line’s Ultra Durable and Low-Profile bumper directly to your Truck. The PRO-2 Bumper features Pro-Line’s unique “Flex Mount” brace that absorbs all impacts rather than transferring them into your Truck and potentially damaging vital components. The two vertically mounted screws that fasten the Bumper to the Brace act as pivot points for the Brace to rotate around allowing the PRO-2 Bumpers to bend but not break. The PRO-2 Bumper was also specifically designed to be as low-profile and minimalistic as possible in order to fit the different types of bodies that Slash® users run on their Trucks. The Front Bumper kit also includes a new Black Bulkhead so you can ditch the ugly grey Stock Bulkhead. If you love Racing and Bashing your Slash® then you need Pro-Line’s new PRO-2 Front Bumper!
#6092-14 is a PRO-2 Rear Bumper for the Slash® 2WD with Pro-Line Transmission. Pro-Line is proud to introduce an all-new Race-inspired Rear Bumper specifically designed around Pro-Line’s Performance Transmission for the 2WD Slash®. The Slash® is the most successful Short Course Truck ever made and now you can add Pro-Line’s Ultra Durable Rear bumper directly to your Truck with Pro-Line’s Transmission. The PRO-2 Bumper features Pro-Line’s unique “Flex Mount” brace that absorbs all impacts rather than transferring them into your Truck and potentially damaging vital components. The two vertically mounted screws that fasten the Bumper to the Brace act as pivot points for the Brace to rotate around allowing the PRO-2 Bumpers to bend but not break. The PRO-2 Bumper was specifically designed around Pro-Line’s Performance Transmission, making it a must have for all who already enjoy the added benefits. If you love Racing and Bashing your Slash® and you have Pro-Line’s Performance Transmission, then you need Pro-Line’s new PRO-2 Rear Bumper!
#6095-00 Front
#6092-14 Rear
PRO-2 Performance Accessories for 2WD Slash®
#6096 is a PRO-2 Hinge Pin Set for the Slash® 2WD. Are you tired of your Stock Slash® Hinge Pins backing out after every run? Are you sick of your Stock Slash® Hinge Pins bending into every shape imaginable other than straight? Pro-Line’s new PRO-2 Hinge Pin Set is the Solution for YOU! Pro-Line’s PRO-2 Hinge Pins are made out of Hardened Steel and are designed to stand up to the abuse of hard off-road racing and bashing action. They are secured using Lock Nuts to prevent your Hinge Pins from ever backing off during your TQ run or Bash session. Problem Solved – Get your PRO-2 Hinge Pins today!
#6097 is a PRO-2 Front Clamping Hex Set for the Slash® 2WD. Pro-Line now has Blue Anodized Aluminum Clamping Hexes for your Slash®! Aluminum hexes are a huge upgrade over the stock plastic hexes in terms of both durability and style. Pro-Line’s new PRO-2 clamping hexes will stand up to the power you throw at your Slash®, will not fall off like the stock plastic hexes and are emblazoned with Pro-Line Blue and a laser etched P-L logo. Trick out your Slash® and get a set of PRO-2 Clamping Hexes now!
#6098 is a PRO-2 Rear Clamping Hex Set for the Slash® 2WD. Pro-Line now has Blue Anodized Aluminum Clamping Hexes for your Slash®! Aluminum hexes are a huge upgrade over the stock plastic hexes in terms of both durability and style. Pro-Line’s new PRO-2 clamping hexes will stand up to the power you throw at your Slash®, will not fall off like the stock plastic hexes and are emblazoned with Pro-Line Blue and a laser etched P-L logo. Trick out your Slash® and get a set of PRO-2 Clamping Hexes now!
#6099 is a PRO-2 ProTrac Axle kit for the Slash® 2WD with ProTrac Suspension Kit (6062-00). Pro-Line’s ProTrac kit is one of the most sought after and important upgrades ever made for your Slash® but the added arm length made it difficult for customers to find the right High Performance Axle kit (beyond the stock drive shafts) that provided optimum fit and performance…until now! Pro-Line is proud to introduce the PRO-2 ProTrac Axle kit for Slash® kits that are outfitted with Pro-Line’s ProTrac kit.
#6096-00 Hinge Pin Set
#6097-00 Front Clamping Hex
#6098-00 Rear Clamping Hex
#6099-00 ProTrac Axle kit
4mm Serrated Wheel Lock Nuts for 2WD & 4WD Slash®, SC10 4×4, SCTE 4×4, 22SCT & Any Vehicle with 4mm Axle
This is a Pack of 4mm Serrated Wheel Lock Nuts for Cars and Trucks with 4mm Axles. Pro-Line wants your wheels to stay where they belong – On Your Car! Pro-Line’s new 4mm Wheel Nuts feature Dual Protection against the Dreaded “Wheel Loss” found at RC tracks around the World. These Pro-Line Blue Anodized Aluminum Nuts have deep serrations that dig into the wheel and provide a secure hold against the rigors of Racing and Bashing. The second layer of protection delivered by Pro-Line’s new Serrated Nuts is the Nylon Lock Ring that prevents the nuts from loosening due to vibration and centrifugal effects. Get the Security and Style afforded by Pro-Line’s new 4mm Serrated Lock Nuts today!
#6100-00
Old 11-22-2012, 07:45 PM
T3GT's Avatar
T3GT T3GT is offline
That Raptor body is SWEET!!!!!
~Billy McGaha~
Racing: RC8B / OS VSpec21 / Ninja 2042 / PL CrowdPleazer - NO Crap-Forward Bodies Here!!
Racing: SC8e / Castle MMM 2200Kv / Ace servos / Gens Ace Batteries / AKA tires
SC8 | SC10 | TC3-Rally | GT | T3 | RC10 | Losi Mini-T | HPI Micro RS4 | Tamiya HotShot
http://www.youtube.com/user/t3gt2000
The TiltYard!!
Old 11-22-2012, 07:52 PM
andystoybox's Avatar
andystoybox andystoybox is offline
I'm happy it isn't one of those butt forward designs that seem to plague everything. I don't like Ford stuff and I would consider running that just because its different.
Show me a Silverado and I'm in for sure!
Old 11-23-2012, 03:55 PM
ravin ravin is offline
http://prolineracing.com/bodies/chev...hd-clear-body/
It's been out a few weeks
Old 11-23-2012, 04:17 PM
nitro-junkie's Avatar
nitro-junkie nitro-junkie is offline
i like the proline bumper kits.
Old 11-23-2012, 06:35 PM
rccardude04's Avatar
rccardude04 rccardude04 is offline
Nice! Maybe a new 4x4 body when the one on it gets beat up!
