Hot News and New Stuff Forum Cars, Trucks, Boats Up-to-the minute news on the latest kits, RTRs, parts, accessories and more. Be sure to subscribe!
Old 10-31-2013, 10:10 AM
Helion RTR Volition 2WD Short Course Truck
Latest from Helion:
The Volition 2wd Short Course Truck offers speed, durability and value unheard of in his class. A 2.4 GHz 3-channel radio system eliminates frequency conflicts, while the 12-turn 550 motor churns out blistering acceleration and incredible top speeds in excess of 30 mph through the beefy all metal gear transmission. Constructed from lightweight yet strong material, the fully independent suspension and oil filled shocks soak up even the worst terrain. A 3000mAh 7-cell NiMH rechargeable battery pack provides excellent runtime while an incredibly efficient LiPo compatible waterproof Metric 30A electronic speed controller (ESC) with reverse puts you in full control. Full ball bearings throughout the vehicle reduce friction and increase runtime. A robust waterproof 6g servo gives crisp steering response while the high grip, long wear tires keep you hooked up over a multitude of surfaces. Included is a 1 Amp A/C wall charger that improves your driving-to-waiting ratio. Visit www.HelionRC.com often so you’ll never be out of touch with the latest innovations headed your way from Helion RC!
Metric 550 High Torque Motor
The Metric 12-Turn motor produces class leading speeds & torque. With an internal fan, the motor runs cooler, maximizing efficiency & sustaining performance.
Metric 30A ESC
The waterproof Electronic Speed Controller (ESC) provides great performance in all weather conditions. The proportional throttle control with reverse & brake is perfect for all skill levels. Ready for upgrades, the ESC supports up to 2s LiPo.
3000mAh Battery &1Amp Charger
A 3000mAh 7-cell NiMh rechargeable battery pack delivers the power necessary to reach speeds in excess of 30 mph while the included 1 Amp charger improves your driving-to-waiting ratio.
HRS-3.1 2.4GHZ Radio System
Utilizing one of the most advanced 2.4GHz radios on the basher market, the HRS-3.1 brings features to your hand that are typically found in high end radios! This product is not only user friendly, but also includes cutting-edge functions such as end point adjustment, dual rates, digital trims, servo reversing & easy binding.
Four wheel independent suspension
Independent suspension provides superior cornering in all conditions and improves handling over jumps and bumps.
Dual bellcrank ball bearing steering with servo saver
The same system found on world champion winning buggies protects precision servo gears in high impact situations.
Low friction telescoping drive shafts
By allowing the driveshafts to extend and contract it dramatically reduces wear and tear in the drive train.
High Speed 12 turn 550 size motor
550 size and 12 turns allows explosive launches and high speeds.
Separate waterproof ESC and 6kg torque servo
Unlike 2 in 1 systems the separate servo and ESC do not require a compromise in placement and quality.
Tool-less battery strap
Keeps the battery secure while retaining easy access without the need for tools or easily lost clips.
Adjustable Body Mounts
Tune the look of your existing body or use the adjustable mounts to fit the many aftermarket body options
Specs:
Lipo compatibility: 2s
Motor: 12T 550 Brushed
Battery: HCT-Plug Connector, Hump Configuration
Gear Pitch: 48P (P:20, S:84)
Wheels: 12mm Hex (24mm OS, TRX and KYO Compatible)
Length: 545mm (21.45in)
Height: 195mm (7.67in)
Width: 296mm (11.65in)
Wheelbase: 331mm (13.03in)
Weight (approx.): 2,240g (4.9lb)
Internal Gear Ratio: 2.62:1
What's in the Box
  • 1x Volition 1:10 Scale 2WD Electric Off-Road Short Course Truck
  • 1x 3000mAh 7-cell NiMH Battery
  • 1x Metric 12T 550 High Torque Brushed Motor
  • 1x Metric 30A ESC
Needed to Complete
  • 4x AA-size batteries for transmitter
$224.99
Old 11-05-2013, 09:34 AM
TIME MACHINE's Avatar
TIME MACHINE TIME MACHINE is offline
I hope Helion nailed it this time. The Dominus was plagued with problems.
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
