Latest from Racers Edge:
Our new aluminum and carbon fiber upgrade parts for The Racers Edge Pro 2 Short Course Truck significantly increase durability and performance, plus they look great too!
The carbon fiber front and rear shock towers and rear chassis plate increase the stiffness over the stock plastic parts allowing the suspension to do all the work, leading to a more consistent driving experience. Multiple angle castor blocks and rear hubs increase durability and aid in fine-tuning your setup for the best lap times. The new aluminum clamping hex hubs ensure you never lose another wheel pin. Aluminum rear hinge pin mounts, front bulkheads and more all in stock now and only available from Racers Edge!
RCETU0216 Vented Slipper Hub 29.99
RCETU0218 Aluminum Servo Saver 2wd 39.99
RCETU0219 Aluminum Castor Blocks 25 Degree 34.99
RCETU0220 Aluminum Castor Blocks 30 Degree 34.99
RCETU0221 Aluminum Rear Arm Mounts (2) 19.99
RCETU0222 Front Bulkhead W/2G Weight 18.99
RCETU0223 Hinge Pin Pivot Ball (8) 5.99
RCETU0224 Aluminum Servo Mount 14.99
RCETU0225 Aluminum 12mm Hex Hub 14.99
RCETU0226 Front Hinge Pin Brace 5.99
RCETU0227 Aluminum Rear Brace Mount W/20G Weight 39.99
RCETU0229 Aluminum Finned Motor Plate 14.99
RCETU0236 Aluminum Rear Hub Carriers 0D 34.99
RCETU0237 Aluminum Rear Hub Carriers 1D 34.99
RCETU0239 Carbon Fiber Rear Chassis Plate (Ball Diff) 34.99
RCETU0243 Carbon Fiber Truck Front Shock Tower 24.99
RCETU0244 Carbon Fiber Truck Rear Shock Tower 29.99
RCETU0248 Aluminum Front Camber Link Mount 34.99
RCETU0254 12mm Hex Hub - 4mm Offset 14.99
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
