New from Atomik RC:
Atomik RC proudly announces the release of the Atomik Racing Catamaran (A.R.C ). This 58” RTR Electric boat is the first large-scale factory electric that out performs it’s gas counterparts. Not to mention, no smelly gas or tedious engine tuning.
After numerous requests for an electric version of our large gas boats, the Atomik design team pulled out all the stops with a whopping 2000 watts of brushless electric power out of the stock 1100Kv outrunner mounted in a water-cooled CNC aluminum motor mount. All that power is controlled with a robust 120A water-cooled ESC for a 40+ mph out of the box top speed.
The hand-laid fiberglass hull features full color Atomik racing color scheme protected by a durable gel coat, pre-installed laser cut radio box and battery tray system, which will accompany a single 6S (22.2V) LiPO battery, but is also expandable for up to a 12S configuration. The A.R.C also comes standard with CNC Aluminum running hardware and the fully adjustable Flexdrive™ system for precise trim tuning.
Standard Features:
- Hand-laid fiberglass hull with full color graphics and gel coat
- CNC aluminum running gear
- Water-cooled CNC aluminum motor mount
- Laser cut plywood internals engineered for multiple electric configurations
- 3-Blade CNC aluminum high performance propeller
- 120 amp water-cooled ESC with pre-installed heavy-duty EC5 connector
- 40+ mph on a standard 6S 22.2V 5000mAh LiPO battery (Not Included)
Age Rating: 14+ With Adult Supervision
Length: 58.0 in (1360 mm)
Overall length: 58 in (1470 mm)
Beam: 15 in (380 mm)
Height: 9 in (230 mm)
Overall Height: 13 in (330 mm)
Weight: 13 lbs (with 6S 5000mAh)
Motor: V700 1100Kv Brushless Outrunner Motor
ESC: Atomik 120A Marine ESC w/ EC5 Connector
Radio: VR3S 3 Channel 2.4GHz Transmitter/Receiver
Recommended Battery: 22.2V 20C+ 5000mAh LiPO
1814 Atomik A.R.C 58" RTR Electric Boat $ 1099.99
In conjunction with this new release, Atomik RC has launched their website and social media sites:
Online
www.atomik-rc.com
Facebook
http://www.facebook.com/AtomikRC
Twitter
http://www.twitter.com/Atomik_RC
